Activity › Forums › Apple Final Cut Pro Legacy › FCP – Skipping Footage
  • FCP – Skipping Footage
    Posted by Thenewblack on July 13, 2007 at 4:56 am
    i recently transfered some DV footage into FCP from my camera.
    i watched the transfer take place and there were no glitches or
    errors on the video.
    after the transfer took place, i attempted to play video back in my
    timeline but noticed that the footage would have a skip/glitch every
    3 seconds or so. this happened with every tape i tried to transfer.
    i went back and viewed the original tapes through the camera and all
    of the original footage plays back perfectly.
    my thoughts are that its something in the preferences but i cant
    figure out what.
    has anyone ever had a similar problem?
    any suggestions????????
    Sean Oneil replied 19 years, 2 months ago 3 Members · 3 Replies
  • Kevin Gardam
    July 13, 2007 at 10:48 am
    Would be agood idea to check your quicktimes outside of FCP, then if all is OK , check your timeline settings in FCP and see they match those of your footage. Further, check your footage resides on drives separate from where your project is being saved.
    Goodluck
  • Thenewblack
    July 13, 2007 at 6:20 pm
    both the session file and video footage are being saved/stored on the same external drive. is this not a good idea?
    also, the footage skips when i view it in the”viewer” in FCP. i havent even taken it to the timeline yet.
    can you think of any specific prefs that i should be looking at?
  • Sean Oneil
    July 14, 2007 at 11:19 pm
    What happens when you play it in Quicktime?
