Activity › Forums › Apple Final Cut Pro Legacy › FCP share for Standard DVD Region Codes
Posted by Steve Cornell on November 19, 2010 at 4:57 pmI used the “share” function of FCP, to make a couple Standard DVD’s. I have to send a few of the discs to Korea and I am wondering about the region codes. Will this disc play in standard dvd players in that country ?
According to wikipedia, Region 0 is playable worldwide but what setting does Share use by default ?
Steve Cornell replied 15 years, 9 months ago 4 Members · 6 Replies -
Zane Barker
November 19, 2010 at 5:34 pmDONT use the share feature.
Use DVD Studio Pro. Export using current settings, then bring into compressor to encode the files for and make them ready for DVD Studio Pro. You will also have much more control over the quality this way.
In DVD Studio Pro you can choose what region to make your disk.
Keep in mind that for you to test the DVD you will need a DVD player with the same region you are making.
**Hindsight is always 1080p**
Rafael Amador
November 19, 2010 at 5:45 pm[Zane Barker] “In DVD Studio Pro you can choose what region to make your disk.
Keep in mind that for you to test the DVD you will need a DVD player with the same region you are making.”
DVDSTP by default will make a DVD playable in all the regions.
You can restrict them.
rafael -
Steve Cornell
November 19, 2010 at 5:48 pmThanks for the input guys. I was wondering if anybody knew what region the ‘share’ utility with FC uses ?
Rafael Amador
November 19, 2010 at 6:07 pm[Steve Cornell] “Thanks for the input guys. I was wondering if anybody knew what region the ‘share’ utility with FC uses ?”
I’ve never used the Share function.
If you don’t see any option, it should be Region Free.
rafael -
Michael Gissing
November 19, 2010 at 7:53 pmIf you play the DVD in a computer, depending on the software, you should be able to display the disk’s data including region coding. Players like VLC should display this info.
Never used Share. When the function first appeared, this forum was peppered with sad stories about trying to use this function. Most of us use the method Zane described.
Steve Cornell
November 19, 2010 at 8:03 pmVLC…that’s perfect. I’ll give that a try.
Personally I love the share feature for BluRay and Standard. The menu is simple and clean. I find it works if the film is under 60 minutes. The shorter the timeline, the more successful that feature is for me.
