Activity › Forums › Apple Final Cut Pro Legacy › FCP settings for PAL
Posted by Josh Kletzkin on September 12, 2009 at 12:04 amHello All.
I’m going to be shooting a project in the UK in PAL format on the Sony EX-1 (1080p/25).
I haven’t shot in PAL before and am wondering if anyone can help me with the proper FCP settings for Log and Transfer/Sequence Settings/Exports.
Any thoughts and/or experience would be greatly appreciated!
Josh
Rafael Amador replied 16 years, 11 months ago 3 Members · 7 Replies -
Rafael Amador
September 12, 2009 at 1:13 amHi Josh,
You don’t need to care much about.
The metadata of the EX-1 files do not allow mistakes by FC. The files are properly recognized (size, time-base, field order,..). Just import and edit.
rafael -
Josh Kletzkin
September 12, 2009 at 4:51 amthanks so much for your response!
i think my question more about how do i set up the PAL settings under “easy set-up” or “sequence settings”? -
Rafael Amador
September 12, 2009 at 6:39 amThere are sequence preset, but you don’t even need that.
Open any sequence, drag a clip and let FC conforms the sequence to the clip.
In HD the only difference between NTSC and PAL is in the time base. Size, pixels aspects and fields order are the same.
rafael -
Josh Kletzkin
September 12, 2009 at 4:19 pmSo FCP will know that my footage was shot PAL at 1080p/25?
Rob Alexander
September 13, 2009 at 9:08 pmPAL/NTSC only exist in the SD world, you’re in HD so it becomes irrelevant.
What is important (as Rafael mentions) is the timebase – in your case 25fps, and frame size (1080). You can use an easy setup or just drop your first clip into a sequence and click OK when FCP tells you it’s best for the sequence settings to be the same as the clip settings.
Josh Kletzkin
September 13, 2009 at 11:09 pmthanks SO much for this!
what would you recommend codec and settings-wise for exports (particularly web) with this camera and workflow? -
Rafael Amador
September 15, 2009 at 2:24 amHi Josh,
just export keeping the 16×9 proportions (320×180, 480×270,..) with Square pixels.
The best codec is H264. Double pass, key frames Automatic and Limit data-rate try 400/500 Kbps.
If your footage is interlaced you need to de-interlaced it.
Cheers,
rafael
