Activity Forums AJA Video Systems FCP settings for digi beta deck
  • FCP settings for digi beta deck
    Posted by Jenelle on March 15, 2007 at 4:28 am
    does anyone know the correct easy setup for a sony digi beta deck? I have deck control, timecode & audio but I can’t see the video & it won’t capture
    Scott Shucher replied 19 years, 5 months ago 3 Members · 2 Replies
  • John Davidson
    March 15, 2007 at 7:56 pm
    I use the Kona 8Bit Uncompressed with a Kona 2 – sometimes I use 10-bit.
    Make sure your deck has SDI selected as input.
    What I/O card do you have? Which deck are you using?
    JD
  • Scott Shucher
    March 15, 2007 at 7:58 pm
    Check you Kona control panel, and make sure you select the correct SDI input.
    The correct capture setting, assuming NTSC is AJA Kona 525 – 29.97 10 bit. (or 8 bit for smaller file sizes
    and a little less quality. For PAL you should use 625-25 10bit.
    How are you getting audio. Embedded, AES or analog?
