Activity Forums Panasonic Cameras FCP settings for different shooting modes
  • FCP settings for different shooting modes
    Posted by Chris Freilich on February 22, 2006 at 12:12 am
    Hi all,
    So I checked out the HVX-200 today for a shoot tomorrow. Using a Powerbook (not a PC, as I had thought) for capturing from the camera. We tested the capture process, and it worked fine for 720P/24P footage, but we had hoped to shoot in 720P/24PN (Native) mode to save space.
    Is it possible to capture footage from the P2 cards via firewire into FCP when shooting in this mode, and if so, what capture settings should be used.
    Also, there are some instructions in the manual on how to connect an external drive directly to the camera, but no instructions on how to use the setup. How do you get footage from the camera directly to the firewire drive? That would be cool. 🙂
    Chris Freilich
    Cinematographer
    Virtuoso Films
    https://www.virtuosofilms.com
    Barry Green replied 20 years, 7 months ago 3 Members · 2 Replies
  • Shane Ross
    February 22, 2006 at 5:38 pm
    Yes, you can get 24PN footage off the cameras P2 cards. Just use the DVCPRO HD 720p24 EASY SETUP and import the footage. There is a section in the manual titled HOW TO GET THE P2 CARD TO MOUNT ON YOUR COMPUTER LIKE A HARD DRIVE or something like that. It is the last section in the EDITING part of the manual.
    And as far as I know, the only way to get footage off the P2 cards is to hook the card to a PC or Powerbook via the PCMCIA slot and download the footage…attach a P2 card reader to the computer…or use a P2 store to download the footage onto. YOu cannot just attach a hard drive to the camera and download that way, you need a device to control the download.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Barry Green
    February 24, 2006 at 3:21 am
    [Chris Freilich] “We tested the capture process, and it worked fine for 720P/24P footage, but we had hoped to shoot in 720P/24PN (Native) mode to save space.”
    Ah, but there’s the cool part — FCP does the “Native” thing for you. If you record 720/24p mode (“Over 60”) so it streams out the firewire, then when FCP 5.0.4 captures the footage it’ll automatically strip out the duplicate frames and save only the active frames. Exactly like 720/24pN.
    So if you’re streaming, don’t worry about the “N” modes, just use the regular mode, and you’ll get what you’re looking for.
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
