Activity Forums Apple Final Cut Pro Legacy FCP sequence was DVCPRO 1280 x 1080..29.97…Need to output for computer playback and internet posting..
  • FCP sequence was DVCPRO 1280 x 1080..29.97…Need to output for computer playback and internet posting..
    Posted by James Dow on June 10, 2014 at 10:37 pm
    What export settings should I use to make this look as good as possible? I usually work in DVCPro 720 at 24P but I was provided with footage that was 1920 x 1080..and I screwed up my sequence. the edit looked good in FCP but my export looked funky, almost square shaped. What should I do?
    Thanks in advance,
    JPD
    JPD
    James Dow replied 12 years, 3 months ago 2 Members · 2 Replies
  • Shane Ross
    June 10, 2014 at 11:18 pm
    What are your sequence settings? Is the sequence interlaced? Does the frame rate match the DVCPRO HD footage? 1920×1080 isn’t square…it’s 16:9.
    Shane
    Little Frog Post
  • James Dow
    June 12, 2014 at 3:56 pm
    It was the 1280×1080 that was looking funky.
    JPD
