Activity Forums Apple Final Cut Pro Legacy FCP Sequence started at 23.98, but needs to be 29.97 – Wizardry required?
  • FCP Sequence started at 23.98, but needs to be 29.97 – Wizardry required?
    Posted by Jon Henry on March 20, 2014 at 1:42 pm
    I have an 8 minute sequence, that was inexplicably started as 23.98 when it needs to be 29.97.
    After searching the web, I haven’t found a way to simply make the 23.98 sequence into a 29.97 sequence. I tried exporting an XML, taking that into Premiere, changing the framerate, exporting and reimporting to FCP, but that didn’t work…I think the sequence is too complicated.
    The simple “copy-and-paste-into-new-29.97-sequence” didn’t work either. The pasted sequence’s media is all over the place.
    I would really appreciate any help on this matter, short of tracking down Gandalf the White, and begging for his help.
    Cheers
    John Pale replied 12 years, 6 months ago 4 Members · 3 Replies
  • Matt Doe
    March 20, 2014 at 2:54 pm
    The only way I know to fix that is to copy and paste from the 23.98 sequence into a new 29.97 sequence.
    Yes, the edits/clips will be out of whack, but you’ll just have to go through and adjust the edits to get it back to how you intended.
    There is no quick/easy fix for this that I am aware of.
  • Shane Ross
    March 20, 2014 at 4:28 pm
    Matt is right…sorry. You’ll have to copy/paste into a proper frame rate sequence, and hunker down for a lot of fixing.
    Shane
    Little Frog Post
  • John Pale
    March 21, 2014 at 1:33 am
    Dave makes an important point.
    If the original footage is 23.98 and the sequence is 23.98, and you need a final output as 29.97, the fix is actually rather simple.
    You can export a reference movie and use Compressor to add the pulldown to get you to 29.97 for file based output.
    If you are outputting to tape, a Kona or Blackmagic card can output with pulldown, as well.
