Activity Forums Apple Final Cut Pro Legacy FCP Sequence Settings for 720p HD from a P2
  • FCP Sequence Settings for 720p HD from a P2
    Posted by Chris Woods on April 4, 2008 at 2:58 am
    I’m currently editing a movie that was shot on HD. I’m not to familiar with HD and the footage was given to me on a Firewire hard drive from a P2 card. I was able to import the footage no problem by converting the films to QT. The question I have is what settings to I put it on in the sequence settings before I start to edit it. I want to make sure it doesn’t use any quality.
    The footage was shot HD 720p/24p. Just wondering what to I set the Aspect Ratio, Pixel AR, Field Dom., Editing Timebase, and QT Compresser.
    Please let me know and thanks for the help.
    Chris
    Chris Woods replied 18 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    April 4, 2008 at 5:22 am
    GO to the FINAL CUT PRO menu, choose EASY SETUP…then choose DVCPRO HD 720p24. Make a new sequence and you are good to go.
    If you have FCP 6, then when you drop a clip into the timeline, it will modify it to match your clip for you…]
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Chris Woods
    April 5, 2008 at 1:38 am
    Thank you very much. I’ll try this. I forgot to mention that I’m working off of FCP 5.0.4. Once I change the easy set up can I change the set up back to normal after I create the new sequence or do I have to leave it on there when I’m working in that project?
    Chris
