Activity Forums Apple Final Cut Pro Legacy FCP sequence and source settings
  • FCP sequence and source settings
    Posted by Pedro Casais on April 19, 2009 at 6:30 pm
    I’d like to ask for a efficient way to match the original settings of my source clips to the sequence to avoid having to render them in the sequence.
    Right now I have video clips shot with my still canon camera. The specs are:
    quick time player (avi,mpg)
    video rate: 30fps
    frame size: 640×480
    pixel aspect: square
    auido rate, 11mhz
    auido format: 8-bit
    When I open a new seq in FCP and try to match these specs with the seq settings option, I still see the two red lines above the timeline and the video as unrendered or playing slowly. On the source monitor, all these clips play fine. Is there a way to avoid rendering?
    Nesreen Alaa replied 17 years, 3 months ago 4 Members · 5 Replies
  • Shane Ross
    April 19, 2009 at 6:35 pm
    YOu have to convert to a format that FCP can work with. Look in the EASY SETUPS to see what formats are available…then convert your footage with COMPRESSOR (Advanced Conversion options) and then bring into FCP to edit.
    FCP does not edit MPEG natively.
    Shane
  • David Roth weiss
    April 19, 2009 at 6:42 pm
    Pedro,
    Watch the following the tutorial, memorize it, and begin every new FCP project precisely as instructed in the tutorial and you will never go wrong.
    https://library.creativecow.net/articles/biscardi_walter/realtime_sequences.php
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Pedro Casais
    April 19, 2009 at 6:55 pm
    Thank you David,
  • Pedro Casais
    April 19, 2009 at 7:09 pm
    Thank you Shane
  • Nesreen Alaa
    June 19, 2009 at 9:04 pm
    I may have the same problem… I set my sequence settings just like the source one… i drag it to the timeline… it warns that the sequence setting doesn’t match the source one ( i dont know why??)
    and once i cut or change opacity or whatever,,, it asks for render??!!!!
    i’m sure that there is a way to fix this… as it also make any action is so slow
    thanks alot
