Activity Forums Apple Final Cut Pro Legacy fcp seq pro res
  • fcp seq pro res
    Posted by Rick Broat on July 26, 2009 at 1:07 am
    I took a project started in fcp express opened it in regular fcp and edited a seq – media is pro res 1920×1080 23.98. I sent the drive and my copy of the project to client and when she opens my seq from my saved project in FCP express she gets an error message: Codec not found. You may be using a compression type without the corresponding hardware card.
    she can play down pro res clips in viewer –
    I had her make a new seq in the original proj. and drag my seq from my project in to it but she still got the same error message.
    When she opens a new seq in her original proj and drops a clip in to it the clip while needing to render does play…..
    when i built my seq i let the clip decide the seq settings. – I don’t know what vers fcp express she has- I was on 6.0.6
    Shane Ross replied 17 years, 2 months ago 4 Members · 5 Replies
  • Steve Eisen
    July 26, 2009 at 1:13 am
    FCExpress does not support ProRes.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Rick Broat
    July 26, 2009 at 1:35 am
    Why do you think that the clients
    fcp xpress can play back the clips in the viewer. and
    They can make a seq and it will play down audio – vid has to be rendered but it will play.
  • Steve Eisen
    July 26, 2009 at 2:56 am
    I don’t use FCE. From what I know it supports DV, HDV and AVCHD only.
    Steve Eisen
    Board of Directors
  • Russell Lasson
    July 26, 2009 at 3:23 am
    And only supports 29.97 frame rates.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Shane Ross
    July 26, 2009 at 4:23 am
    QT 7.5.5 and up has a built in ProRes decoder. You can see it and play it, but as you said, you couldn’t work with it without rendering. it was rendering it to AIC.
    Shane
