Activity Forums Apple Final Cut Pro Legacy FCP SD Tape out and PTVTmp Files
  • FCP SD Tape out and PTVTmp Files
    Posted by Jim Fink on October 10, 2012 at 4:14 pm
    So, I have been exporting some 80 minute shows to DigiBeta with an AJA IO. The current sequence is a 4ch. output. Previous outputs spend but a few minutes writing a temp file and then going out to tape.
    Currently system is spending about 40 minutes writing a PTVTmp File to the Render Folder. Why is this happening. Usually it only writes a short header and starts right up. I restarted, and relaunched FCP 7 and same.
    All is rendered, settings are same as stereo version was. Any clue to why the systems needs to build such a large pre-roll file. It’s writen about 60 gig so far.
    Jim Fink
    New Century Digital Media
    Chapel Hill, NC
    Avid|DS
    (919) 929-5228 Voice or 423-4363 (Cel)
    https://www.NCDM.TV
    jim@ncdm.tv
    Jim Fink replied 13 years, 11 months ago 2 Members · 2 Replies
  • Michael Gissing
    October 10, 2012 at 8:45 pm
    The need to render indicates that you have not fully rendered before edit to tape. Check your render settings in the render menu
  • Jim Fink
    October 10, 2012 at 9:37 pm
    All is rendered – no change before or after tape out. Pretty much a flat file I am outputting to tape.
    Jim Fink
    Chapel Hill, NC
    Avid|DS
    https://www.NCDM.TV
    jim@ncdm.tv
