Activity › Forums › Apple Final Cut Pro Legacy › FCP Run Slow using External Drive
Posted by Milton Hockman on August 16, 2009 at 4:48 amIm making podcasts.
Sequence is set up as 1024×768 Animation.
Clips i recorded are same specs.Running 2.16 Intel iMac.
External firewire 400 WD Caviar Black 1TB.When editing my clips it is running super slow! I see the drive light flickering on an off. I can’t move aroun din the sequence even. total lag!
WHy is that? All media is on the external drive.
John Pale replied 17 years ago 4 Members · 6 Replies -
John Pale
August 16, 2009 at 5:03 amAnimation is not a real time codec. Use a codec there are easy setups for, such as uncompressed or ProRes. You will never get good performance with custom non-standard settings
David Roth weiss
August 16, 2009 at 5:10 am[John Pale] “Use a codec there are easy setups for, such as uncompressed or ProRes.”
John,
He won’t be able to playback uncompressed off a firewire 400 drive without dropping frames either.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Milton Hockman
August 16, 2009 at 6:55 amhow should i have my settings? Should i set them to a DV codec to edit with, and then switch to animation when outputting?
Motion Graphics Artist and Non-Linear Editor
Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more. -
Margus Voll
August 16, 2009 at 7:42 amHI.
Try and go with ProRez. If it works use that. DV has less color information and may give you head ace 🙂
Option would be replacing external drive to FW 800 or something better.
Margus
Milton Hockman
August 16, 2009 at 8:03 amwhy is it taking so longn to export a quicktime movie reference?
my video is 7mins long and its going to take 20 mins just for a refernece file!Motion Graphics Artist and Non-Linear Editor
John Pale
August 16, 2009 at 3:24 pmAck. Good point…gonna need at least FW800 for that (and even that might be dicey as the drive fills up)
