Activity › Forums › Apple Final Cut Pro Legacy › FCP Resize Algorithm
Posted by Eugene Lehnert on April 30, 2009 at 11:13 pmWhat algorithm does Final Cut use when resizing a shot using the motion tab?
Rafael Amador replied 17 years, 4 months ago 5 Members · 6 Replies -
Rafael Amador
May 1, 2009 at 1:25 amHi Eugene,
FC have three quality levels when rendering Motion Effects.
You can choose in the sequence setting Linear/Normal/Best.
No idea of the filters that FC use for up/downscaling.
If you use the “Rotation” function, all those Motion Effects will be rendered Linear.
rafael -
Chris Borjis
May 1, 2009 at 7:12 amEugene I can tell what it isn’t….it is not Bi-Cubic like
it is in Sony Vegas.I wish apple would address that, its a real pain not having
good high quality resizing….kinda comes in handy huh? -
Eugene Lehnert
May 1, 2009 at 11:04 pmYeah. I use our UKON to upconvert and downconvert the video material that I get but sometimes I use the motion tab to blow stuff up by a small percentage when it’s progressive material. I wanted to see if I could get a plug-in that used similar algorithms as the Snell & Willcox Ukon.
John Fishback
May 2, 2009 at 8:37 pmWhile Video Purifier by Innobits is most known for its video noise reduction it also has an excellent scaler. https://www.innobits.com/purifier.html
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24″ TV-Logic Monitor
Final Cut Studio 2 (up to date)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Todd Beazley
May 3, 2009 at 4:55 amDepends on sequence settings. I tested these once using anappropriate test pattern. Fast setting uses (bi)linear interpolation (same as used in canvas). Normal and Best settings appear to add fairly sharp anti-alias filtering, couldn’t tell how the interpolation method changed.
Best is slightly better than Normal, Normal is way better than Fast.
Todd B.
Rafael Amador
May 3, 2009 at 1:26 pmThe FC manual have been really improving with the years but still miss some very important info.
Nothing about those filters.
Rafael
