Activity Forums Apple Final Cut Pro Legacy FCP requiring that I render imported still images
  • FCP requiring that I render imported still images
    Posted by Doug Normington on March 21, 2006 at 2:58 pm
    I have FCP set up for NTSC DV. I have a pilke of historical images cripped 720×540 and ready to go. Everytime I import one I get the dreaded redline.
    What do I have to do so I wont have to render every single one of these?
    NORMCO
    Steve Eisen replied 20 years, 6 months ago 5 Members · 4 Replies
  • Bret Williams
    March 21, 2006 at 3:16 pm
    Resizing them to the native size of DV 720×480 will be less overhead for the processor, but they’re still not in the DV codec so they need to eventually be rendered in any case.
  • Jeff Carpenter
    March 21, 2006 at 3:28 pm
    You could try messing around with the playback settings to lower the preview quality. You might be able to turn it into an orange line instead of a red one. You’d still have to render at the end, but you might be able to get some work done before you have to render which can be a big time-saver.
  • David Roth weiss
    March 21, 2006 at 3:50 pm
    Norm,
    Are you using FCP 4 or 4.5 by any chance?
    DRW
  • Steve Eisen
    March 21, 2006 at 3:53 pm
    You did not mention what format your stills were. JPEG, TIFF, etc. You also do not have your computer’s configuration. You will always have to render still images. Depending on your system, FCP version and RT Settings, you should be able to monitor your stills in realtime.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
