Activity Forums Apple Final Cut Pro Legacy FCP reports audio rate error when exporting WMV files
  • FCP reports audio rate error when exporting WMV files
    Posted by Jerrold Le tourneau on August 27, 2007 at 12:54 pm
    Ok, simple task take 35 video clips all ingested via 8-bit uncompressed 48k stereo and export as MPEG-1, Quicktime and WMV format. Put each clip into it’s own timeline. Select all timelines in FCP browser and select “export using compressor”. Compressor opens, select all 35 items and assign presets for MPEG-1, Quicktime and WMV (using Flip4Mac to make the WMV files). All clips assigned 3 different encoding settings. Should be staright forward took about 15 minutes to set everything up.
    So I hit the submit button and compressor chugs away without issue throught the MPEG-1 and Quicktime encoding. Then it hits the WMVs and warns “Inconsistent Audio Sample Rate. The media I am exporting contains audio with multiple sample rates.” Ok? but that wasn’t an issue for the MPEG-1 or Quicktime encoding. So I check the clip audio settings as report in FCP and they match the settings for the timeline. There are not audio or video edits on the clips. Clips are inserted into timeline as is – no “in” or “out” points. So I try again the process jsut for the WMV from Compressor. Same error msg. Welll then I try doing a batch export from within FCP — same error.
    I hate the simple projects as they always seems to blow up. GIve me complicated project instead. I need to make WMV files. Anybody what is going on here?
    10.4.10
    Dula 2Ghz PowerPC G5
    1 GB DDR SDRAM
    FCP 5.1.4
    Quicktime 7.2.0
    Bob Cole replied 18 years, 11 months ago 5 Members · 5 Replies
  • Tom Brooks
    August 27, 2007 at 1:40 pm
    This was in my inbox recently:
    The recent release of QuickTime 7.2 created an audio compression error for Flip4Mac WMV Studio, Studio Pro and Studio Pro HD customers. Specifically, when encoding WMV files with Flip4Mac WMV v.2.1.2 using uncompressed audio sources on QuickTime 7.2 systems, customers were receiving “Inconsistent Audio Sample Rate” error and the encode will fail. This problem has been resolved with the beta release of Flip4Mac WMV v2.1.33. If you are using QuickTime 7.2, please upgrade to this release at
    https://www.flip4mac.com/wmv_beta.htm
  • Jerrold Le tourneau
    August 27, 2007 at 2:05 pm
    Thanks, I was about to loose my mind.
  • Mark Palmos
    August 31, 2007 at 9:35 am
    yep, a relief for me too!
    thanks
    mark.
  • Creekbank Films
    September 7, 2007 at 5:05 pm
    That’s the ticket! For the life of me I couldn’t figure out what was wrong? You saved the day Tom.
    Cheers!
  • Bob Cole
    September 23, 2007 at 12:55 pm
    me too — thanks a lot for the tip!
    bob c
    MacPro 2 x 3GHz dualcore; 2 GB 667MHz
    Kona LHe
    Sony HDV Z1
    Sony HDV M25U
    HD-Connect MI
    Betacam UVW1800
    DVCPro AJ-D650
