Activity Forums Apple Final Cut Pro Legacy FCP Rendering Problem
  • FCP Rendering Problem
    Posted by Daniel Monskey on November 24, 2009 at 9:32 pm
    I am working on a FCP project (5.0.4) on a laptop with 5 external LaCie drives. When I attempt to render the project it only goes to about 23% (everytime) and gives me the perpetual rainbow ball. I go to FORCE QUIT and select FCP (which shows it is not responding). It doesn’t close. I then hold the start button to shut it down and start all over, never getting anything rendered.
    I’ve tried copying the project and working with that but I have no luck. I even try rendering one clip at a time—only moderate luck. It is a long project with lots of clips. I would prefer not having to start over.
    Any suggestions?
    Dan
    Daniel Monskey
    Daniel Monskey replied 16 years, 10 months ago 1 Member · 1 Reply
  • Daniel Monskey
    November 24, 2009 at 11:11 pm
    Thanks for your help. After I posted the question I disconnected the harddrives from the NITRO firewire 800 hub and plugged directly into the computer. Problem solved—rendering and processing fast & fine. This is the first time I’ve had problems with squeezing data through the hub.
    Daniel Monskey
