Activity Forums AJA Video Systems FCP Render??
  • FCP Render??
    Posted by Chris Childs on May 9, 2007 at 9:06 pm
    Hey folks,
    Running a Mac Pro with FCP 5 and AJA Io and I am all of a sudden getting four channels of audio instead of just 2 and I have to render everything until I can edit…what is going on any ideas??
    Thanks in Advance..
    Chris
    Jeremy Garchow replied 19 years, 3 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    May 9, 2007 at 11:10 pm
    In the log and capture window, click on the clip properties tab and choose your audio inputs there. You are needing to render because you have captured to a format that does not match your timeline. Adjust your timeline to fit your captured settings by hitting control-q to being up the easy setups. Choose the proper setup and away you go.
    Jeremy
  • Chris Childs
    May 10, 2007 at 6:21 pm
    Great Thanks Jeremy in diving into those menus I saw that someone had changed the frame rate…fixed right away..
    Chris
  • Jeremy Garchow
    May 11, 2007 at 3:06 am
    Sweetness…good catch!
