Activity › Forums › Apple Final Cut Pro Legacy › FCP Render Problem
  • FCP Render Problem
    Posted by Jill Ricketts on April 4, 2005 at 5:40 pm
    Even after reinstalling the program and cleaning off capture/scratch/render files, I am only able to render one ore two times. After that the render flashes on then goes away. OSX 10.3.8, FCP 4.5.
    I have to close down and reopen the program then to render again.
    Thanks to anyone who can help,
    Jill Ricketts
    Ardee Productions
    Lincoln, NE
    David Hails replied 21 years, 6 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    April 4, 2005 at 9:10 pm
    Have you set the render settings properly in the Sequence menu? Render selection, render all, etc…?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Hails
    April 5, 2005 at 5:58 pm
    I also have the same problem all the render settings appear to be fine. Is there a particular way they should be set up?
    I would realy appreciate any help to sort out this problem.
    Dave
