Activity › Forums › Apple Final Cut Pro Legacy › FCP Removing Handy Cam look with out De-interlace
Posted by Joseph Ryan on December 18, 2008 at 12:36 pmHi
I am using FCP (5.1.4).
What I was told a while ago was, if I wanted to get rid of that handy cam look (tinny look) I should De-interlace (Effects, Video Filters, Video, De-interlace) my footage. This does work, but the footage is not as sharp, especially when it is moving footage which is what I film a lot of. I thought this was the way it was so I put up with it.Recently I saw the result of some filming (shot on Mini DV) which was 100% sharper (clearer) and did not have that handy came look.
I was wondering if anybody may have any ideas on how to achieve this with out using De-interlace?
I had tried a film effect too but it is very jumping with moving footage.
I hope there is a basic solution and my question look like it has come from a newbe (as I am).
Any help or suggestion would be greatly appreciated as I don’t know anyone else that films, so most of the time it feel like I am walking through the jungle at night and keep smacking my head into trees.
Regards
JosephDavid Roth weiss replied 17 years, 9 months ago 6 Members · 11 Replies -
Jerry Hofmann
December 18, 2008 at 1:00 pmQuit shooting interlaced video… 24p or 30p will give you the look you’re after. When you deinterlace interlaced video you are throwing away about 1/2 the resolution. It’s something you should do if the end result is to be a web stream, but if it’s going to tape or DVD to be played on a TV set, you’ll lower that resolution if you do it.
So to get to where you want to go, you need to replace the camera if it doesn’t shoot a progressive format.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
Joseph Ryan
December 18, 2008 at 1:20 pmThank Jerry for your reply
I had a quick scan on the internet to see if my camera shoots progressive format. I have a Canon XL2, on one site is said it did but I have a PAL version of the XL2 and on it is only an option of 25p or 50i. I gather there must have been an updated version there some where? I also have a sony HVR-A1P but no idea what that shoots.
So if I can’t find it in the manual that there is a 24p or a 30p shooting option. It means I have to save up again for a new camera and will have to put up with it for now?
I gather there are not other solutions to this?
So thanks for you help again.
Joseph
Joseph Ryan
December 18, 2008 at 1:57 pmHi Jerry
Sorry to annoy you again but after digging my manual out my Canon XL2 has a option of 25p which it says is progressive, but it then says:
25p Mode
Records in 25 fps progressive mode and outputs signals converted into 50 fps interlace.Would you or anyone know if this meant that I am still going to have interlaced footage. To me how it is written seem to suggest that it will record onto the tape in interlaced. If that is true if I was saving to a hard drive instead of tape would this solve that problem.
Hope that makes sense
Regards
Joseph -
Marc Brak
December 18, 2008 at 2:48 pmNo, it does record progressive. It may output a 50 fps interlaced signal, but since the two interlaced frames per second are created from one ‘whole’ (progressive) frame, the fields (the lines of which an interlaced picture consists) add up to one progressive frame 🙂
Does that make sense? 😉
Screw it, let’s do it!
Rafael Amador
December 18, 2008 at 3:22 pmBut in which country are you Joseph?
You have a camera that shots i50 and p25, so is PAL.
But you want to shot p30 or p24 that are NTSC time bases. You need another camera.
However any “p” (p24,p25,p30..) will give you the progressive look that you my be looking for.
Rafael -
David Roth weiss
December 18, 2008 at 4:38 pmJoseph,
Color correction is just as important to your mission as dealing with the interlace. I’m CCing a feature at this very moment shot on about twenty different Handy Cams, and I assure you, it doesn’t have the”Handy Cam look.”
To begin with, I’ll bet that your black levels aren’t properly set. Do you know what they should be? Have you checked them?
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Joseph Ryan
December 18, 2008 at 8:52 pmHi Rafael
I am in Australia, so yes that why it is Pal, thanks for letting me know 25p will be the same as 30p or 24p. I mainly shot surf footage, freewayproject.com and that is why the interlace problem has been such an issue, with all the movement I fill.
Thanks again
Joseph -
Joseph Ryan
December 18, 2008 at 9:03 pmHi Marc
I think I get what you mean (as I had a quick read on interlace). Because interlace has its image information over 2 frames (odd and evens) when I was de-interlacing I was taking away half the information there or losing the quality. With progresses as each frame rate is whole.
Thanks for your reply, it is greatly appreciated.
Regards
Joseph -
Joseph Ryan
December 18, 2008 at 9:20 pmHi David
Thanks for your reply, as I mention earlier in the thread I have two camera’s and one I do not think has a progressive setting. This camera is used for water footage as I mainly shoot surfing ( freewayproject.com ) so if there is anything I can do to get both cameras footage looking like I need that would be really helpful.
I have adjusted my black settings but that was just a guess as I was trying to remove that handy cam look, but no, I have no idea if what I did was even close to correct. I normally have been making my darks a little darker, and giving a little bit more colour saturation. But this is just guessing. If you have any information about Colour Correction that could help me out, or somewhere that I could read up on it, it would be greatly appreciated.
So the answer to your questions
“I’ll bet that your black levels aren’t properly set.” they are probably not set correctly
“Do you know what they should be?” no idea, I just guess
“Have you checked them?” yes I have checked them, but that doesn’t mean I knowing what I am doing.And again with the colour correction issue it is like I am walking through a jungle at night and I keep smacking my head into trees.
Again thanks for your reply and help
Regards
Joseph -
Sean Oneil
December 18, 2008 at 10:13 pm[Joseph Ryan] “Because interlace has its image information over 2 frames (odd and evens) when I was de-interlacing I was taking away half the information there or losing the quality. With progresses as each frame rate is whole.”
That is correct.
Sean
