Activity Forums Apple Final Cut Pro Legacy FCP Referencing Media Incorrectly
  • FCP Referencing Media Incorrectly
    Posted by Scott Stolzar on April 21, 2011 at 3:27 pm
    I’m working on a project that mixes DVCPro 720p24 media with clips that were converted to ProRes (LT) SD at 23.98 (the sequence settings are DVCPro 720p24). We finished a cut and did a full render, but noticed that quite a few of clips had slipped by various amounts. When I tried to match back to the master clip, it matches back to a completely different part of the clip. I deleted all of the preferences and caches to see if that would do the trick but no luck. I’m starting to bake out quicktimes and replace the shots in the cut, but as I’ve come across this problem before, I was wondering if you have any other suggestions on how I can fix this, either by preventing it in the first place or somehow fixing it so that FCP references the media properly.
    I’m running FCP 7.0.3 on an iMac with 4 gb of RAM, processor is 2.8 GHz Intel Core i7 and it is running OS X 10.7.6.
    Thanks in advance for your help!
    Scott Stolzar replied 15 years, 5 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    April 21, 2011 at 3:56 pm
    Trash your render files (not just caches) and try again.
    Jeremy
  • Scott Stolzar
    April 21, 2011 at 3:59 pm
    Thanks! I had tried that but still had the problem.
