Activity › Forums › Compression Techniques › FCP ref movie to Squeeze
  • FCP ref movie to Squeeze
    Posted by Shay Carriere on July 25, 2007 at 6:30 pm
    I’m having an issue with pixelation when compressing a QT movie with Sorenson. I’m exporting a QT movie at project settings; DV NTSC size/frame rate/aspect ratio with lower field first. As expected, the graphics look crisp when opened again with FCP and pixelated and somewhat nasty when opened directly with QT. After exporting it from Squeeze at a variety of different compression settings (QT large/small preset, etc), I find that the titling throughout the clip at every setting looks quite.. umm, not-crisp. My titles generated in AE have a 3pt stroke outlining them, and this looks particularly hideous.
    Should I be using Squeezes deinterlacing filter prior to compressing this clip? Am I somehow missing a step converting interlaced to progressive in FCP? Or are my expectations from Sorenson too high? I’ve seen really sharp graphics and titles on many sites and am curious as to the compression scheme used…
    Thanks for any info
    Sorry for the long post.
    Craig Seeman replied 19 years, 2 months ago 2 Members · 1 Reply
  • Craig Seeman
    July 25, 2007 at 8:42 pm
    FCP uses Quicktime as its “base.” If you open an FCP DV ref movie (or self contained) you’ll see the interlacing and the video pixel aspect ratio.
    As to what’s happening in Squeeze it may very well depend on what settings you’re using. Squeeze doesn’t have the most flexible processing filters but you’d need to post the details, settings, preprocessing (if any) you’re using. Also keep in mind that DV isn’t the best codec to work in if you’re expecting “crisp” (or even smooth) graphics.
