Activity Forums Apple Final Cut Pro FCP reduces exported mp4 resolution without warning
  • FCP reduces exported mp4 resolution without warning
    Posted by Connor Hawke on April 21, 2022 at 3:56 am
    My video project is HD-vertical (1080×1920). After exporting it as an mp4 by using the settings Computer and H.264 Better Quality at the export prompt, I see that the resolution of the exported video has downgraded without warning to 608×1080 – although the Resolution in the export prompt itself was listed as 1080×1920! I’m having to use a third-party mov-to-mp4 converter (like the online Adobe Premier converter) as a workaround to maintain 1080×1920. How do I get FCP to export mp4s in the set resolution?
    Jeremy Garchow replied 4 years, 4 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    April 21, 2022 at 10:38 am
    What is the Project resolution set to?
    I just exported a load of vertical video to mp4 out of fcpx yesterday and all went well.
  • Connor Hawke
    April 21, 2022 at 3:02 pm
    Project resolution is also Vertical 1080×1920.
    FCP and macOS are up-to-date (10.6.2 and 12.3.1 respectively).
    Edit: I found a suggestion that it might be a bug and to try re-selecting the desired resolution in the export prompt. Since on the prompt dropdown it was already set as 1080×1920, I changed the dropdown value to 720×1280, then back to 1080×1920, before exporting. Immediately I saw that the estimated size was significantly greater than before the switch. And it worked! Exported resolution was vertical-HD. Reported the bug to Apple.
  • Jeremy Garchow
    April 21, 2022 at 4:23 pm
    I would try trashing your FCPX preferences too.
