Activity › Forums › Apple Final Cut Pro Legacy › FCP & Red workflow question
  • FCP & Red workflow question
    Posted by Peter Humble on August 11, 2013 at 10:43 pm
    New to Red and in sorting out my workflow it’s raised another question re Log & Transfer.
    I’ve downloaded Redcine-x Pro to transcode the footage to ProRes (proxy) plus I installed the Red FCP plug-in. So far so good.
    My first step was to test two transcoding paths:
    1. Via Redcine xPro
    2. Via FCP Log & Transfer
    In my tests, the FCP Log & Transfer is about 95% faster than Redcine xPro. In other words the Redcine x Pro is so slow that it’s almost unworkable. I assume this is the limits of using a laptop without a dedicated card. Correct??
    My 2nd issue is with the FCP log and transfer. I’m trying to transcode to a ProRes Proxy of 1920 x 1080 but I can’t find anywhere in the Log & Transfer Preferences to specify this. It automatically transcodes the clips to 2240 x 960. So, despite it being fast, I can’t get the size I want.
    Is it possible to re-size/change output size in Log & Transfer
    Any thoughts on this?
    Specs:
    Macbook Pro –
    OSX: 10.8.3
    2.2 GHz Intel Core i7
    RAM: 8GB
    FCP 7.0.3
    Thank you
    Peter Humble replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
