Activity Forums Apple Final Cut Pro Legacy FCP Recognition Problem, Anybody else have the Sony M-10U?
  • FCP Recognition Problem, Anybody else have the Sony M-10U?
    Posted by Chip Whiting on May 25, 2005 at 7:30 pm
    Wow, this upgrade is a bit worrysome, unless I’m doing something wrong. I’ve used FCP since version 1.0 and have never had issues like these. First up, my deck will play, log shots and be controlled by the log and capture window, but it won’t capture a thing. If I try “capture now” It says there is no data coming in. If it’s being controlled and logging shots, why doesn’t it see the data? Second, you can’t preview through thr monitor unless you print to video? This is not cool. When I went to the Apple presentation at NAB, they said nothing about that that I can recall. Do I need to get an aja box or something? All in all, FCP is an awesome program, and it is a bargain to say the least, I’m sure I’ll get it all worked out with the help of the Cow!
    Chip
    Dual 2 gig g5
    4 gig ram
    Newest Tiger update
    Steve Connor replied 21 years, 3 months ago 2 Members · 3 Replies
  • Steve Connor
    May 25, 2005 at 8:42 pm
    Hi, we had the same problem, you have DV downconvert set to ON in the menu, you need to switch this to OFF.
    I know it’s not cool you can’t monitor through the HDV machine like you can in DV, it’s a limitation of the format NOT FCP. you need to add an HD card if you want pro quality video output or add a 23″ cinema display for monitoring via Digital Desktop.
    Steve Connor
    Cardinal HD
  • Chip Whiting
    May 25, 2005 at 9:54 pm
    Thanks Steve. What is a good HD card to get? I definately need one of those!
    Chip Whiting
    99 Productions LLC
    541-343-0099
  • Steve Connor
    May 26, 2005 at 4:48 am
    Decklink HD or Kona 2, they both have forums here at the COW
    Steve Connor
    Cardinal HD
