Activity Forums Apple Final Cut Pro Legacy FCP re-reads movie data each time
  • FCP re-reads movie data each time
    Posted by Jerry Levin on April 13, 2010 at 12:18 am
    Hi all.
    I’m still new to FCP (2 months), but am gaining speed.
    I have a project that needs to have two separate authors working on it. OS is 10.6.3, FCP is 7.0.2.
    The goal is to have two machines, two authors (but only one author working at a time). When one author’s done, he mails the FCP project file to the other other. We know that when the new project file’s opened on the other machine source media needs to be reconnected (and then a re-render). We aren’t adding any new media.
    I’ve cloned all the folders from the original machine to the second machine; it now has the same folder tree and source content as the original machine along with the FCP project file.
    Launching the FCP project works on the 2nd machine; just have to reconnect the media (expected).
    What’s not expected; each time this project file is launched on the 2nd machine, it wants to read each of the media files (there are some 75 movie clips); this takes around 20 minutes. It’s not looking for the files, but reading them. This only happens on the 2nd machine. Launching FCP with a new project file doesn’t do this (also expected as it’s not trying to read the media).
    Specifically:
    Actual message is:
    “Searching for movie data in file foo.mov”
    This happens while the project is loading, and has the progress bar:
    Preparing video for display (dialog box title is “Reading project”)
    If I copy the FCP file from the 2nd machine back to the first, launch (and reconnect as expected), FCP launches w/o problem. It doesn’t try to read the media.
    There are a number of other things I’ve tried, but to no avail, including full render, etc.
    Has anyone seen this behavior before?
    FCP is configured the same on both boxes: base config is 422Prores HQ, I believe other settings (as best I can tell from side-by-side comparison) are the same as well.
    Quite mystified and appreciative of any help offered.
    Many thanks for your help!
    Jerry
    Jerry Levin replied 16 years, 4 months ago 2 Members · 7 Replies
  • 7 Replies
  • Tom Wolsky
    April 13, 2010 at 1:32 am
    First, they’re called editors.
    Second, preparing video for display is not “reading the video.” It’s better not to make up terminology. This is usually a project memory issue. One way around this is to make sure you have closed all sequences before you quit the application. Or launch the application holding the Option key.
    This can also be caused by defective RAM. It can also be caused by an incorrectly installed operating system and application.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Jerry Levin
    April 13, 2010 at 2:12 am
    Hi Tom. Thanks for quick response and clarifications.
    To elaborate:
    The original machine that the project was created on works perfectly fine.
    I cloned the folder tree to two other machines that are actually far more capable (more recent CPU, 4 gig instead of 2; just newer boxes). It’d be strange (though not impossible) for them to both have memory related issues.
    Both exhibit the exact same issue of “Searching for movie data in file foo.mov”, and do this for all 75 .MOV files.
    This happens even if I’ve just booted the machines, have just launched FCP for the first time since booting up the box.
    Here’s a sequence I went through on both machines, sorry to be verbose but perhaps there’s a hint you may recognize:
    1. I created a new, empty project file, closed FCP, and re-opened FCP. no problems.
    2. With the new project, I imported all the movie clips, saved, closed and reopened the project. Again no problem.
    3. I opened the project file that works perfectly on the original machine, by copying it to the problematic machine. After the project finished loading with the issue described, I cut and pasted the sequence into the newly created project. Saved the newly created project file, quit FCP, rebooted the machine. Launched FCP and opened the new project. Same problem.
    4. With FCP running, I ensured that it would *not* open last project in user prefs. Quit and rebooted machine. Launched FCP. It *still* displays the same problem, even when opening a new project. When it’s finished loading, this appears to be an empty file; i.e. no media, no bins, just a “virgin” project. Why would it reference media that a new project isn’t “connected” to?
    How would one verify that the app is properly installed, or hasn’t been corrupted? I do know that the other editor has done a force quit as there’s no clean way to abort out of the problem…
    I have also launched FCP with the Option key, but w/o change in the behaviors described.
    Again – thanks.
    PS – with regard to making up terminology: fair enough – I’m here to learn and appreciate the chance to learn best practices and vernacular. For the term “reading”, this stems explicitly from the dialog box title, “Reading project”, along with the displayed message “searching … in file foo.mov”. Thanks…
    Jerry
  • Tom Wolsky
    April 13, 2010 at 3:26 am
    I’m confused here, is it happening on both machines or on one?
    Have you trashed your preferences?
    Details of the machines, OS, and QT would help. Are they all using the same versions of the OS, QT, and FCP? What is it?
    This is actually what the error message says? Even after trashing prefs and opening a blank project?
    All the best,
    Tom
  • Jerry Levin
    April 13, 2010 at 4:05 am
    There are 3 machines: one original which works perfectly, two that repro the identical problem.
    OS:
    Working machine: 10.6.3, 2.33 Ghz Intel Core 2 Duo (MacBookPro2.1), 2 Gig RAM
    1st problem machine: 10.6.2, 2.8 Ghz Intel Core 2 Duo, MacBookPro5.2, 4 Gig RAM
    QT Player:
    All machines 10.0
    FCP:
    All machines: 7.0.2
    The text actually reads:
    “Searching for movie data in file foo.mov” where “foo.mov” changes for each of the 75 MOV file names that are the source files. Example: “Cam1_A.mov”, Cam1_B.mov” all the way through Cam3_X.mov.
    And yes this happens even after trashed prefs, and a new (empty) project file that’s opened.
    Rebooting both the machine and FCP, even with “open last project” unchecked still repros this.
    Interesting, eh?
    Thanks in advance for your thoughts…
    Jerry
    Jerry
  • Jerry Levin
    April 13, 2010 at 4:07 am
    One add’l comment – I only posted info about one of the two problematic machines. The other one which is a tower config isn’t here for me to check on OS and app versions.
    Jerry
    Jerry
  • Tom Wolsky
    April 13, 2010 at 8:59 am
    There is no way after trashing preferences and launching the application, not an existing project, that FCP will look for video.
    Are you sure it’s FCP looking for the video and not the system?
    How was the OS and apps installed on these machines? Are they new machines with the OS preinstalled, or where they upgraded? Was this done with a clean erase and install from discs, or otherwise?
    All the best,
    Tom
  • Jerry Levin
    April 13, 2010 at 5:55 pm
    Hi Tom…
    More information here (thanks for staying with this).
    1. After trashing prefs, FCP boots cleanly.
    2. If I open the real project file, FCP goes through the searching movie behavior.
    3. I allow FCP to finish opening the project, and then quit. When I launch FCP again it still goes through the same search behavior, even though *this* time it opens to a new project (i.e. “open last project” is not checked).
    4. FCP will continue to go through this until I trash the prefs again. Bizarre.
    On a separate note,
    1. Trashed user prefs, ensured FCP was launching clean
    2. I plugged the original external disk from the working laptop into the new, problematic laptop (after disconnecting the disk with copied files).
    3. Launched FCP with the desired project file – all worked fine. There’s obviously some file(s) needed to satisfy FCP, but have no idea what, but at least this is a tangible hint).
    Insights?
    Jerry
