Activity › Forums › Apple Final Cut Pro Legacy › FCP quits unexpectedly, G5 Quad woes
  • FCP quits unexpectedly, G5 Quad woes
    Posted by Jay Curlee on April 6, 2006 at 10:02 pm
    First I get the DC G5 Quad refurb from Apple yesterday and discover that there is no wireless card. My network is Airport.
    I used migration manager to move my FCP 5.0.4 from my existing G5 DP 1.8. I try to open FCP, I get as far as “unable to find firewire device” click on continue, and program quits unexpectedly. Can’t report it because there is no wireless card.
    Here is what the report says:
    Date/Time: 2006-04-06 11:05:19.730 -1000
    OS Version: 10.4.2 (Build 8E90)
    Report Version: 3
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [53]
    Version: 5.0 (5.0)
    Build Version: 2
    Project Name: FCPApp
    Source Version: 504212200
    PID: 13091
    Thread: Unknown
    Link (dyld) error:
    Symbol not found: _kQTImageBufferUseHighQualityGammaCorrectionKey
    Referenced from: /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    Expected in: /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
    Model: PowerMac11,2, BootROM 5.2.7f1, 4 processors, PowerPC G5 (1.1), 2.5 GHz, 4.5 GB
    Graphics: NVIDIA GeForce 6600, GeForce 6600, PCI, 256 MB
    Memory Module: DIMM0/J6700, 256 MB, DDR2 SDRAM, PC2-4200U-444
    Memory Module: DIMM1/J6800, 256 MB, DDR2 SDRAM, PC2-4200U-444
    Memory Module: DIMM2/J6900, 2 GB, DDR2 SDRAM, PC2-4200U-444
    Memory Module: DIMM3/J7000, 2 GB, DDR2 SDRAM, PC2-4200U-444
    PCI Card: GeForce 6600, Display, SLOT-1
    PCI Card: bcom5714, network, GIGE
    Serial ATA Device: Maxtor 6L250M0, 233.76 GB
    Parallel ATA Device: HL-DT-ST DVD-RW GWA-4165B, 1.01 GB
    USB Device: Hub in Apple Pro Keyboard, Chicony, Up to 12 Mb/sec, 500 mA
    USB Device: Apple Optical USB Mouse, Mitsumi Electric, Up to 1.5 Mb/sec, 100 mA
    USB Device: Apple Pro Keyboard, Chicony, Up to 12 Mb/sec, 250 mA
    FireWire Device: unknown_device, unknown_value, Up to 400 Mb/sec
    Can anyone offer a solution or translation to this?
    Jay
    BTW, I decided to re-install Final Cut Pro Studio from the discs can got the same result. 2 more hours wasted.
    Jay Curlee replied 20 years, 6 months ago 3 Members · 3 Replies
  • Matthew Brunn
    April 6, 2006 at 11:06 pm
    Wipe the startup drive and install everything from ground up. Don’t use the migration manager with a system that you need rock solid. It’s not worth the extra time and in the end you may have to.
    Hope this helps-
    Matthew
    Quad 2.5 G5
    OSX 10.4.X
    Ram 4GB
    FCP 4.5/AE 6.5/DVDSP3
  • Michaelle Stikich
    April 6, 2006 at 11:15 pm
    It looks like you are missing some Quicktime components. I would download the full install of Quicktime 7 and reinstall it.
    gir
  • Jay Curlee
    April 7, 2006 at 12:22 am
    Well gir, you are the big winner. Sneakered a fresh QT download over there and bingo.
    Many thanks. Let’s see what else happens.
    Jay
