Activity › Forums › AJA Video Systems › FCP quits unexpectedly
  • FCP quits unexpectedly
    Posted by Nanette Binon on July 12, 2010 at 6:58 pm
    I have tried everything to open this app-trashing prefs, resetting PRAM, verifying disk-all to no avail.
    Can someone please help me?
    I get this problem report when FCP quits:
    Process: Final Cut Pro [257]
    Path: /Applications/Final Cut Pro Old.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 5.0.4 (5.0.4)
    Build Info: FCPApp-512141418~2
    Code Type: PPC (Translated)
    Parent Process: launchd [109]
    Date/Time: 2010-07-12 01:59:22.524 -0700
    OS Version: Mac OS X 10.6.4 (10F569)
    Report Version: 6
    Interval Since Last Report: 14789 sec
    Crashes Since Last Report: 44
    Per-App Crashes Since Last Report: 44
    Anonymous UUID: 9B54DD71-A7DE-440D-A17D-B63CCDAD53A8
    Exception Type: EXC_CRASH (SIGTRAP)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
    Thread 0 Crashed: Dispatch queue: com.apple.main-thread
    0 libSystem.B.dylib 0x802362b2 __pthread_kill + 10
    1 libSystem.B.dylib 0x80235b5f pthread_kill + 95
    2 com.apple.FinalCutPro 0xb80bfb30 0xb8000000 + 785200
    3 com.apple.FinalCutPro 0xb80c0037 0xb8000000 + 786487
    4 com.apple.FinalCutPro 0xb80dd8e8 0xb8000000 + 907496
    5 com.apple.FinalCutPro 0xb8145397 spin_lock_wrapper + 1791
    6 com.apple.FinalCutPro 0xb801ceb7 0xb8000000 + 118455
    Thread 1:
    0 libSystem.B.dylib 0x801400fa mach_msg_trap + 10
    1 libSystem.B.dylib 0x80140867 mach_msg + 68
    2 com.apple.FinalCutPro 0xb819440f CallPPCFunctionAtAddressInt + 206231
    3 libSystem.B.dylib 0x8016d81d _pthread_start + 345
    4 libSystem.B.dylib 0x8016d6a2 thread_start + 34
    Thread 0 crashed with X86 Thread State (32-bit):
    eax: 0x00000000 ebx: 0x802f8500 ecx: 0xb7fff9ac edx: 0x802362b2
    edi: 0xb8211640 esi: 0x00000005 ebp: 0xb7fff9d8 esp: 0xb7fff9ac
    ss: 0x0000001f efl: 0x00000286 eip: 0x802362b2 cs: 0x00000007
    ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
    cr2: 0x802362a8
    Binary Images:
    0x80000000 – 0x8005bff7 com.apple.framework.IOKit 2.0 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x8007a000 – 0x800e4fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) /usr/lib/libstdc++.6.dylib
    0x8013f000 – 0x802e5feb libSystem.B.dylib 125.2.0 (compatibility 1.0.0) /usr/lib/libSystem.B.dylib
    0x80366000 – 0x804e0fe3 com.apple.CoreFoundation 6.6.3 (550.29) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x805d8000 – 0x805e6fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) /usr/lib/libz.1.dylib
    0x805eb000 – 0x805f7ff7 libkxld.dylib ??? (???) /usr/lib/system/libkxld.dylib
    0x805fb000 – 0x80641ff7 libauto.dylib ??? (???) /usr/lib/libauto.dylib
    0x8064e000 – 0x807d0fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) /usr/lib/libicucore.A.dylib
    0x80832000 – 0x808dffe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) /usr/lib/libobjc.A.dylib
    0x808f3000 – 0x808f6fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) /usr/lib/system/libmathCommon.A.dylib
    0x8fe00000 – 0x8fe4162b dyld 132.1 (???) /usr/lib/dyld
    0xb8000000 – 0xb81defff com.apple.FinalCutPro 5.0.4 (5.0.4) /Applications/Final Cut Pro Old.app/Contents/MacOS/Final Cut Pro
    0xffff0000 – 0xffff1fff libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
    Translated Code Information:
    objc[257]: garbage collection is ON
    NO CRASH REPORT
    Unable to gather system configuration information.
    Joseph Owens replied 16 years, 2 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    July 12, 2010 at 7:42 pm
    FCP v5.0.4 and OS 10.6.4?
    That might have something to do with it.
  • Joseph Owens
    August 2, 2010 at 7:46 pm
    I started getting this kind of behaviour last October when I committed the serious error of upgrading to Snow Leopard.
    For me the situation stabilized a bit with the Non-Desktop Driver (NDD) version of the latest Kona3 software. Now I get occasional panics with FCP errors using the Kona plugin which results in a system crash. Most annoyingly, the Edit to Tape module is just insane with frequent hangups on the 9-pin RS422 control, which nothing but a full system shutdown and restore will fix.
    jPo
    You mean “Old Ben”? Ben Kenobi?
