Activity Forums Apple Final Cut Pro Legacy FCP question
  • Posted by Gracias on May 9, 2005 at 8:42 am
    Hello,
    Just keen to know How much KB per frame FCP captures on uncompressed & compressed mode.
    Since Avid is giving 800KB per frame. R we closer to it.
    Also I checked inmy G5 machince on FCP 4.5HD ican’t do manual trimming i.e when I drag it through mouse trim doesn’t happen. I ve found it when my timeline is more than 45mts of editied footage.
    Regrds
    Minto
    Tom Volotta replied 21 years, 4 months ago 4 Members · 3 Replies
  • Walter Biscardi
    May 9, 2005 at 11:43 am
    8bit uncompressed is generally 20mb/sec while 10bit uncompressed is around 30-40mb/sec. You can figure the per frame rate from there.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Shane Ross
    May 9, 2005 at 2:09 pm
    Did you press”R” to get the Roll tool? Press “N” to turn off Snapping? Tried double clicking on the cut to open trim mode?
    any of those work for you?
  • Tom Volotta
    May 9, 2005 at 3:57 pm
    Walter,
    I know it’s only a typo on your part, but just so Gracias doesn’t get confused…
    It’s 20MBps (MegaBytes per second) and 30-40MBps, not megabits per second as the lower-case ‘b’ in “8bit…20mb/sec” implies, for 8 and 10-bit UC. e.g., DV/DVCAM is 25Mbps.
    Gracias, download the AJA Data Rate Calculator to determine size and data rate for a wide range of formats. Be sure to open “Preferences” for details on Binary and Decimal measurement.
    https://www.aja.com/support_Io.html
