Activity › Forums › Apple Final Cut Pro Legacy › FCP ProRes Easy Setup
Posted by Frank Giardina on April 13, 2011 at 4:54 pmHi…
I’m working with 1920 x 1080 transcoded footage from a 7D and 60D. The Easy Setup in FCP gives you a 1440 x 1080 sequence. Drop in the first clip and FCP asks if you want to conform to the footage. I’m thinking yes.
Just want to make sure.
Best Regards 🙂
Frank Giardina
17 Video ProductionFrank Giardina replied 15 years, 5 months ago 2 Members · 4 Replies -
David Roth weiss
April 13, 2011 at 5:22 pmDoes not compute…
First, transcoded to what?
Second, FCP does not ask if you want to conform the footage, it should ask if you want FCP to change the seq. settings to match the media. Is your FCP different from all others?
The answer to number two above is most likely yes, if you want to edit without rendering every step of the way then idealy FCP should change the seq, settings so they match the media you’re working with.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
Frank Giardina
April 13, 2011 at 5:52 pmHi David…
No, same Final Cut 🙂 … just didn’t get much sleep last night.
The footage was transcoded to ProRes 422 and I did have FC change the seq. settings to match the media. Just second guessing and thinking about it while I’m at the other job.
Thankfully, I’m finally in a situation where I didn’t have HDV in the mix.
Thanks Again David!
Frank Giardina
17 Video Production -
David Roth weiss
April 13, 2011 at 7:01 pmGlad you’re running smoothly Frank. Now that you’ve got this all down, you can look forward to learning it all over again in the new FCX this June.
David Roth Weiss
Los Angeles
Frank Giardina
April 13, 2011 at 7:18 pmHi David…
I subscribed to the that thread … I hear you there 🙂
Frank Giardina
17 Video Production
