Activity Forums Apple Final Cut Pro Legacy FCP Project Wont Open
  • FCP Project Wont Open
    Posted by Jimmy Stewart on August 2, 2006 at 7:06 pm
    I created a project in FCP 4.5. A friend took the project and finished cutting it on a newer version of FCP. I now have the project back and when I try to open it the following pops up:
    “File’s format is too new for this version of the application.”
    It won’t let me open the project. What should I do to open the project?
    Sebas replied 20 years, 1 month ago 4 Members · 3 Replies
  • Roddy Jamieson
    August 2, 2006 at 7:21 pm
    I think you will find that it’s not backwards compatible. You will have to upgrade.
    Roddy Jamieson
  • Johnw3d
    August 3, 2006 at 12:30 am
    You might also be able to export to XML in the newer FCP and import that in 4.5. Use the earliest verion XML export format available in the newer FCP.
  • Sebas
    August 3, 2006 at 1:54 am
    the xml works. you’ll have the cuts but you’ll lose some other info (filters, etc)
