Activity Forums Apple Final Cut Pro Legacy FCP project won’t open from Finder
  • FCP project won’t open from Finder
    Posted by Rob Womack on April 14, 2010 at 3:24 pm
    Peculiar behavior: Final Cut stops opening projects double-clicked in the finder, after being open for a while. It’s inconsistent, so I can’t give steps to reproduce, but it happens often. When it happens, if I quit FCS 3, FCP will not prompt me to save changes. Quit acts like a force quit. I’ve trashed the prefs and run FCS maintenace pack utilities on it to no avail. Any clues as to why?
    Rob Womack replied 16 years, 4 months ago 2 Members · 2 Replies
  • John Pale
    April 14, 2010 at 4:31 pm
    Sounds like an OS problem, as trashing prefs did not fix it. This is happening with all projects? Not just certain ones?
    Try downloading Onyx and using it to clean your caches. You might also try repairing permissions, Disk Warrior, etc.
  • Rob Womack
    April 14, 2010 at 6:10 pm
    It only does this in Final Cut on a variety of projects that share the same footage files. Quitting FCP restores the normal behavior, so I don’t think it’s an OS issue. I just have to go through each project in the browser and manually save, or else I have to go to the autosave vault.
    Robert Womack
    Creative Bridgekeep
    http://www.CurrentMarketing.com
    “Louisville’s Leading Interactive Marketing Agency”
