Activity Forums Apple Final Cut Pro Legacy FCP problems w/Tiger
  • FCP problems w/Tiger
    Posted by Rymyjo on January 21, 2007 at 2:24 am
    I am a new user to Final Cut Pro HD.
    I recently upgraded my G4 to Tiger, and also installed MBox with ProTools LE and am now experiencing several problems with FCP that I did not have before the upgrade.
    1) Video clips will not play (only audio). This is also the case when I try to play quicktime movies directly from a disk. The one exception to video that I can see are previous sequences made with FCP before getting Tiger.
    2) Sequences will not render.
    3) When I export to Compressor, and try to submit, I am given the message
    “Cannot connect to background process”
    I have been told to reinstall Compressor and ditch my FCP preferences, but doing neither of these has helped. Any help is greatly appreciated.
    Ryan
    Rymyjo replied 19 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    January 21, 2007 at 4:04 am
    What version of QT are you using?
    Rafael
  • Rymyjo
    January 21, 2007 at 4:07 am
    QT version is 7.1.3
  • 13 Create COW Profile Image
    13
    January 21, 2007 at 5:51 am
    Did you do a clean install?
    It is always best to erase and install instead of upgrading to a whole new version (10.3 to 10.4 for example)
  • Rymyjo
    January 21, 2007 at 6:09 am
    No, I just ran the Tiger installation disk…and that’s when all the problems started. If I remove Tiger and reinstall do you think that will help? Thanks
    Ryan
  • Rafael Amador
    January 21, 2007 at 11:26 am
    I would rather reinstall FC and up-date the ProApp Support etc. Don’t forget reppair permissions after any intallation.
    Salud,
    Rafael
  • Rymyjo
    January 21, 2007 at 2:20 pm
    Thanks for the tip. The only problem is that I do not have FC to reinstall. I bought the computer from someone with it already installed. Any suggestions?
    RYan
    13
    January 21, 2007 at 4:13 pm
    I would suggest getting a legal copy of Final Cut.
  • Chuck Reti
    January 21, 2007 at 4:38 pm
    [rymyjo] “I have been told to reinstall Compressor and ditch my FCP preferences, but doing neither of these has helped.”
    and
    …I do not have FC to reinstall. I bought the computer from someone with it already installed.”
    So how could you reinstall Compressor if you don’t have the FCP HD install disk?
    Quick search at Apple support brings up this troubleshooting document:
    https://docs.info.apple.com/article.html?artnum=93234
  • Rymyjo
    January 21, 2007 at 6:11 pm
    I have DVD Studio Pro 2, which comes with Compressor on it.
