Activity › Forums › Apple Final Cut Pro Legacy › FCP Problem Upgrading
  • FCP Problem Upgrading
    Posted by Anthony Spirito on July 2, 2010 at 6:15 pm
    Greetings,
    I had to uninstall FCP studio 6 from my machine and re-install FCP 5.1; which I did, with no problem. 5.1 runs and seems to be functional. When I go to Software Update to install 5.1.4 it downloads it, but when it gets to the install part, it craps out on me, saying there is an error. I’ve repaired disk permissions, but that didn’t seem to work. And I’ve simply just downloaded it and launched it as a “package” but then it won’t let me install on my HD. I have a client that only edits in 5.1.4 and we exchange projects back and forth, hence why I need 5.1.4. Any suggestions/ideas are greatly appreciated. Thanks in advance!
    Best,
    Anthony S.
    Anthony Spirito replied 16 years, 3 months ago 3 Members · 4 Replies
  • Zane Barker
    July 2, 2010 at 7:21 pm
    Save yourself a big headache and completely erase the hard drive install a clean OS and then install FCP.
    Hindsight is always 1080p
  • Anthony Spirito
    July 2, 2010 at 7:26 pm
    There’s got to be a better way than that, no? Erase the entire hard drive? There’s so much I would need to back up, it’d take me more than a day to get the machine ready to zap it. I don’t have the kind of time.
    AS
  • Craig Alan
    July 3, 2010 at 4:47 pm
    Easy solution use:
    https://www.digitalrebellion.com/fcs_remover.htm
    Here’s a recommendation from a reliable source:
    https://www.lafcpug.org/reviews/review_fcs_maintennance_stone.html
    But if you are not backed up and start clean when trouble hits you are asking for more trouble:
    Get yourself an external drive and download CCC. Make a clone of your system. Now everything is backed up. Boot from the back up just to make sure everything went well. Repair permissions. Reformat your system drive and there you have it.
    Since you only want to downgrade for one client, why not do a clean install of the OS on another external drive, install 5.x and run update? Then for this project only, boot from the external drive. You’ll have a clean system to work from. On the other hand, you might have trouble reinstalling 6.x on your system drive and will get the same advice to start clean.
    The pro apps installs like to start clean. Sooner of later system drives develop problems and the best way to deal with it is with a clean install. Which means you need to have a complete back up and all your install disks of your apps. Almost all else are documents, which can be easily dragged over to your new documents folder from a back up.
    Using disk utility, you can make disc images of all your install discs and save them on the root level of your cloned back-up. Mount them on the desk top of your clean new system drive and launch them from there. This is time saving because you are now installing from a hard drive not a cd. Plus no more loading and unloading cds. If you mount them on your desktop and get the first install disc going, it will automatically launch the others. Huge time saver.
    Yes this will take a day. And you might need to tweak some things as you launch them such as preferences within an app. But you will also have clean and better functioning system. And when something bad happens like your system drive dies or gets corrupted, you won’t miss a beat. If your computer dies or is in for repair, you can now boot from your clone with a loaner and you won’t miss a beat.
    If your stuff is not backed up now, you are asking for disaster.
    https://eshop.macsales.com/search/7200+sata+drives
    https://eshop.macsales.com/Catalog_Page.cfm? parent=3035&title=Voyager%20by%20NewerTech%2D%20Hard%20Drive%20Dock%20for%203%2E5%22%20and%202%2E5%22%20SATA%20Devices%20provides%20high%2Dperformance%20and%20flexibility&ti=4520
    OSX 10.5.7; MAC Book PRO (EARLY 2008); Camcorders: Sony Z7U, Canon HV30, Sony vx2000/PD170, Canon xl2; Pana, Sony, and Canon consumer cams; FCP certified; write professionally for a variety of media; teach video production in L.A.
  • Anthony Spirito
    July 4, 2010 at 12:31 am
    Thanks for that detailed account on how to go about things, I appreciate it!
    Best,
    Anthony S.
