Activity Forums Sony Cameras FCP Pro Res Plays Over Firewire?
  • FCP Pro Res Plays Over Firewire?
    Posted by Kevin Jones on April 22, 2008 at 1:47 pm
    I dropped an EX-1 1080i project onto a timeline setup in FCP Easy Setup for DV-NTSC Firewire Basic. I changed the rendering to Pro res and rendered the timeline as usual. Looks great and plays fine over firewire to my DVCAM deck.
    It seems counter-intuitive that a Pro res rendered project would play over firewire. Could someone in-the-know explain how this works.
    Kevin Jones
    2.5GHz Quad-core PowerPC G5
    Final Cut Studio 2
    Andy Mees replied 18 years, 5 months ago 4 Members · 5 Replies
  • Noah Kadner
    April 22, 2008 at 2:56 pm
    It’s actually not- FCP is downconverting ProRes to DV on the fly…
    Noah
    My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
    https://www.callboxlive.com
  • Craig Seeman
    April 22, 2008 at 7:22 pm
    And you can even edit in XDCAM EX native and it’ll spit that out firewire too (and spit is kinda accurate because that’s what it’ll look like).
  • Kevin Jones
    April 23, 2008 at 3:19 am
    Craig, you might be able to answer this.
    In the Easy Setup menus there are several different version of DV available. What is the difference?
    Thanks.
    kj
    Final Cut Studio 2
  • Noah Kadner
    April 23, 2008 at 6:12 pm
    DV is DV- there’s no different flavors just the frame rates and PAL vs. NTSC.
    Noah
  • Andy Mees
    April 26, 2008 at 4:49 pm
    well you have the plain vanilla DV PAL or DV NTSC settings … use these setups if you’ve shot bulk standard 4:3 DV
    then you have the Anamorphic variants ,… use these if you have shot in “widescreen” mode with your 4:3 DV camera, or in DV mode with your 16:9 HDV camera
    then there are the “Firewire Basic” variants … use these if you are having problems getting your camera to be recognised or controlled with FCP (most commonly this is needed with Canon’s DV cameras)
