Activity Forums Apple Final Cut Pro Legacy FCP & Pro Apps Video All Dark
  • FCP & Pro Apps Video All Dark
    Posted by Chris Armstrong on February 22, 2011 at 7:55 pm
    A couple of weeks ago I updated from 10.6.4 to 10.6.6 and installed all the various security and ProApp updates.
    Since then, all of my video and image files in the ProApps (FCP, DVDSP, etc) have had a really dark image.
    Now if I render this out and open it in Quicktime it looks fine, but anything in FCP looks really really dark.
    I’m sure this is some silly colorsync / gamma read issue, but I don’t even know where to start to find a solution. Any suggestions? Anyone experienced something like this before?
    Ivo Machado replied 14 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • Nathaniel Cooper
    February 22, 2011 at 11:37 pm
    Apple changed the IRE settings in 10.6, but there shouldn’t be a change from 10.6.4 to 10.6.6. The changes they did to the IRE settings can make a file look ‘darker’ on the screen, however it’s actually more acturate to the video. But, this should have been updated when you moved to any version of 10.6 and should affect non pro apps and pro apps just the same.
    Is the video outputting okay after you do your work in FCP? Do you have a reference monitor output? If so is it darker there too?
    You may want to try trashing your FCP prefs and rebooting, if you haven’t already.
    Nate Cooper
    nate.cooper@promax.com
    office: 949.861.2725
    cell: 949.375.2738
    I support:
    Xsan
    MXFserver
    Promax ShareMAX
    EVO/SANmp
    EditShare
    MetaSAN
    Small Tree
    NAS solutions
  • Chris Armstrong
    February 22, 2011 at 11:52 pm
    It only seems to be an issue with the Apple FCS apps. Nuke and other non-FCS apps show the files fine. (Qucktime works fine) And if I run the video out to a broadcast monitor it looks fine.
    It has something to do with the way the FCS apps are showing files on the LCD’s. It’s as if it is showing it with a crazy dark gamma.
    I’ve tried deleting all the preferences and reseting settings, but that didn’t help. Next step is to completely remove FCS and reinstall and see if that makes a difference.
  • Erik Sulcs
    March 7, 2011 at 8:02 pm
    Did you ever resolve this issue? My FCP 7.0.3
    Has been doing the same thing. I see the video just fine with perfect Iris levels in my Panasonic AG-HPX170. As soon as the video is in FCP it is really dark. It even exports looking way too dark…
    I also recently updated to 10.6.6 What if anything did you do to resolve the issue?
    Thanks…
  • Chris Armstrong
    March 7, 2011 at 11:56 pm
    Yes I resolve it.
    Turns out my “Display Profile” had gotten changed. Once I returned it to a normal profile everything looked fine after that.
  • Erik Sulcs
    March 8, 2011 at 2:04 pm
    Chris,
    Sorry I’m a bit of a newbie here, but where exactly is the “Display Profile” you mention?
    Is it something in FCP or in the OS? I did a search in both and nothing matched…
    Erik
  • Chris Armstrong
    March 8, 2011 at 6:10 pm
    Click on OS X’s “System Preferences”, then click “Display” in the hardware category. Then click on the “color” tab.
  • Erik Sulcs
    March 8, 2011 at 6:46 pm
    Thanks for the info…
  • Mitch Netzer
    August 31, 2011 at 7:02 pm
    Perfect! My display preferences randomly changed themselves from 60hrz NTSC to 50hrz PAL and changed color driver types. Super weird. Changed them back and all is fine now. Didn’t even have to restart final cut or my mac!
  • Eric Dubé
    September 27, 2011 at 8:07 pm
    Hi i have the same problem, i did what you said and click on color tab and try all the menu could not get rid of the darkness.
    Hepl
    Eric
  • Ivo Machado
    June 29, 2012 at 11:54 pm
    I’ve been having this problem for along time. I think I just figured out.
    Go to the Sequence Settings (Cmd + 0) on Compressor switch to Apple Pro Res 422.
    It works for me 🙂
