Activity › Forums › Apple Final Cut Pro Legacy › FCP Pluraleyes workflow
Michael Gissing
December 20, 2010 at 9:50 pmYou don’t need house sync or a workclock generator. Both FCP and ProTools on internal will maintain sample to sample accuracy. Make sure the timelines are both the identical frame rate and timecode type (Drop/ non drop etc)
The final mix will be a wav or aif file. Bring that into FCP and drop it onto the sequence timeline. Read this first –
https://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
The most common issue with sync is the way FCP imports audio assets.
