Activity › Forums › Apple Final Cut Pro Legacy › FCP on PC??
FCP on PC??
Posted by J. Tad newberry on January 26, 2010 at 5:57 pmI’m 99% sure FCP (and FCS) will ONLY run on a Mac, isn’t that true? But i’ve heard a few people are convinced it will run on a PC. Which is true?
Thanks again!
J. Tad Newberry
Big Ya Productions
Mac Pro 2.66 GHz Quad-Core
3 GB RAM
http://www.bigya.tvMark Maness replied 16 years, 7 months ago 7 Members · 9 Replies -
Bj Ahlen
January 26, 2010 at 6:09 pmSome people have installed hacked BIOS chips on their PCs, to create a “Hackintosh.”
Let’s say you do this, and you’re able to make FCS work initially.
Then one day you have a problem. Do you think Apple will take your trouble report?
Do you think the pros in this forum will spend time to try to figure out if your problem is in FCS or in a Hackintosh incompatibility?
Rafael Amador
January 26, 2010 at 6:15 pmIt seems that is possible install it and even open it.
Edit and operate, I don’t know.
I guess you have to know a lot of programing to cheat FC and convince him that that PC is a MAC.
Updating is seems that is another no easy operation. In the end you would spend so much in brain, that would be anti economic.
I think that is the kind of things only justified if you are to impress a girl or go to jail, because, I guess, is illegal.
rafael -
John Foley
January 27, 2010 at 12:31 amCheat a PC? The Intel MAC IS a PC with an Intel platform boot process for a GUID disk drive format.
There are a few careful steps you need to consider to get the PC BIOS to look like a MAC’s EFI Firmware, but it is done.
Bj Ahlen
January 27, 2010 at 1:28 amSure, it has been done by quite a few enthusiasts who cared more about being “cool” than about having a supported system that would always be there for them when needed.
A student with no deadlines could potentially save some bucks, but if you’re a working professional you could end up having to tell the client: “Sorry, I couldn’t finish you project on time because Apple and other pros can’t support FCP on my cheap pirate box.”
Michael Sacci
January 27, 2010 at 7:33 amBack to the original question, the software will only run on Mac OS, it will not install on Windows, if that is what you were asking.
Luke Pearson
January 27, 2010 at 2:16 pmOn certain PC motherboards you didn’t even need to ‘hack’ the bios, you can download a ‘hacked’ osx installer from a torrent and just run it during bootup, providing your PC is fairly up to date it’ll install no problem and if you need drivers for anything they can mostly be found online.
I’ve tested it and it does work quite well, I even managed to do an edit in Final Cut, the only problem I encountered was exporting to an NTFS drive within my PC but if you were to format all your drives to GUID that wouldn’t be an issue.
Obviously if you do this you will have zero support and it’s against the OSX EULA. I should also add that I managed to kill my Creative Audigy soundcard by installing the wrong drivers in OSX, I’ve no idea why it killed the card, maybe it tried to install some new firmware or something???
Mark Maness
January 27, 2010 at 3:19 pmIsn’t that kinda like asking for a Lamborghini with an automatic transmission? Why?
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
J. Tad newberry
January 27, 2010 at 7:51 pmSo what are you guys REALLY trying to say??? : )
Hey, thanks again so much for the input. I was pretty sure these would be the answers, but have a client who had “heard” they could run FCS on their PC. I first said, “No”, but then thought I should look into it. will now change my answer to, “HELL NO!”
Thanks again!
J. Tad Newberry
Big Ya Productions
3 GB RAM
http://www.bigya.tv -
Mark Maness
January 27, 2010 at 9:49 pm[J. Tad Newberry] “Hey, thanks again so much for the input. I was pretty sure these would be the answers, but have a client who had “heard” they could run FCS on their PC. I first said, “No”, but then thought I should look into it. will now change my answer to, “HELL NO!””
I think the proper response would be… WTF!!
Wayne Carey
Schazam Productions
