Activity Forums Apple Final Cut Pro Legacy FCP on a Macbook Pro
  • FCP on a Macbook Pro
    Posted by Frederico Silva on March 19, 2010 at 4:13 pm
    Hi there
    I have a Macbook Pro with 2.4Ghz Core2duo, 2GB ram.
    I have a sequence with 920×720 with a video(originally 1920×1080)
    the Video has 1min and 21 sec.
    And just a few effects like: 3 color balance filter, 1 -Sharpen, 3 Magic Bullet filters(LS bleach, LS Nº 85, MisFire Vignette), Color corrector 3way, Frames(Magic Bullet de-interlace filter)
    it takes like 10 hours to export to quicktime(current settings)
    I dont have experience in editing HD, and using color filters. Is this a acceptable rendering time?
    What is your experience with a similar system and FCP color adjustments or AE in terms of rendering time?
    Fred
    Sam Ellens replied 16 years, 5 months ago 3 Members · 2 Replies
  • Shane Ross
    March 19, 2010 at 5:32 pm
    You said the dimensions, but NOT the codec. What codec? DVCPRO HD? ProRes?
    [frederico silva] “I have a sequence with 920×720 with a video(originally 1920×1080) “
    Those are VERY odd numbers. Not a normal ratio for FCP. If the sequence settings and footage doesn’t match something you find in the Easy Setups, then yes, they can take a long time. But also, you have a LOT of render intensive filters, like FRAMES. That does take time too. You have a lot of factors that are adding up to a long render time.
    Shane
  • Sam Ellens
    March 20, 2010 at 12:33 am
    The only 960×720 footage I’ve seen came from DVCPro HD 720, but I rarely get 720 footage.
    and I love that this is considered a small number of filters by some. renders take a long time, and they take even longer on a macbook pro.
    Sam Ellens
    Intern – Zamasti Films
    4th year at Ryerson University – Radio and Television Arts
    My system: iMac 21.5 3.06GhZ 4GB
