Activity › Forums › Apple Final Cut Pro Legacy › fcp omf export timecode
  • fcp omf export timecode
    Posted by David Mercer on June 20, 2010 at 7:58 pm
    Does an exported Omf timecode default to 01:00:00:00 even though the FCP timeline / sequence is set to 10:00:00:00?
    If so if there a way to change it within FCP so that all future OMF’s default to 10:00:00:00 ?
    Many Thanks
    David Mercer
    David Mercer replied 16 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    June 20, 2010 at 10:48 pm
    An OMF exports the sequence timecode. If you want it to start at 10hrs, then make that first frame in your sequence. The point of an OMF is that it is identical to the source both in tracks and timecode.
  • David Mercer
    June 21, 2010 at 12:07 am
    That’s what I thought.
    D
    Many Thanks
    David Mercer
