Activity Forums Apple Final Cut Pro Legacy FCP Offline to Online Workflows
  • FCP Offline to Online Workflows
    Posted by Paco Sweetman on September 19, 2010 at 9:04 pm
    Can anyone point me in the right direction of some tutorials regarding offline and online workflows in FCP.
    I’ve looked online but it seems to be a needle in a haystack topic.
    I’ve got a whole project on my Macpro, I’ve media managed it to an Offline RT (HD) format. I want to be able to take it on my laptop when I’m away from my Macpro to work on it, and then update back onto the Macpro when I’m back. I’d like to be able to do this as much as possible.
    Thanks in advance.
    I’m using FCP 7 on both machines.
    Paco Sweetman replied 16 years ago 4 Members · 7 Replies
  • 7 Replies
  • Chad Tingle
    September 19, 2010 at 9:25 pm
    [Paco Sweetman] “I want to be able to take it on my laptop when I’m away from my Macpro to work on it, and then update back onto the Macpro when I’m back. I’d like to be able to do this as much as possible.”
    The easiest way to accomplish this is to copy all the media that you have on the mac pro to an external drive as an exact copy of what’s on the mac pro. If you update something on the mac pro.. say for e.g you add some music and a photoshop file then you should do the same thing on the external.. If you keep everything exactly the same on both the external and mac pro media drive. you can simply exchange only the project files between computers and all the media will re-link.
    Chad Tingle
    Producer/Editor
  • Paco Sweetman
    September 19, 2010 at 9:31 pm
    Is there not a way to do a workaround without an external hard drive. The amount of media is about 250GB. The offline media is only about 17GB.
    What about if I cut the offline stuff and then export and EDL?
  • Chad Tingle
    September 19, 2010 at 9:53 pm
    [Paco Sweetman] “Is there not a way to do a workaround without an external hard drive. The amount of media is about 250GB. The offline media is only about 17GB.”
    just copy the offline media and the project file to your mac pro then.. That should work fine as well.. The key thing to remember is just to be sure that both computers have the exact media.
    Chad Tingle
    Producer/Editor
  • Shane Ross
    September 19, 2010 at 10:40 pm
  • Paco Sweetman
    September 19, 2010 at 11:06 pm
    Thanks Shane, I’m gonna check it out.
  • Donal O kane
    September 20, 2010 at 10:19 am
    Is this Paco that went to Clonkeen?
  • Paco Sweetman
    September 20, 2010 at 11:16 am
    It is. Howz it going Donal?
