FCP novice with a question…
Hey everyone-
Maybe you guys can help me out here. I’m a novice at FCP and I am trying to achieve a few things…not to sure if they can even be done:
If I look in the sequence settings page, I see you can select up to 24 output tracks (in either stereo or dual mono pairs). I am choosing 4 so I match the 4 track inputs of our various capture devices (XDCAM, Digi, BetaSp, DVCam etc).
If I have a hypothetical session that has say MONO VO on TRK 1, MONO FX on track 2 and STEREO MUSIC on track 3/4, can I output a full mix to FCP outs 1/2 as well as a mix minus vo to FCP outs 3/4 in one pass?
Can I make these assignments in the audio mixer window?? I obviously need to assign every track to FCP outputs 1/2 (which is easy), but then what about assigning only SELECT tracks to outputs 3/4? The goal is to do ONE pass laybacks.
Any help would be greatly appreciated.
-Toby
