Activity › Forums › Apple Final Cut Pro Legacy › FCP not seeing firewire camera
Posted by Ross Marshall on October 9, 2006 at 6:10 pmPlease help recently updated my operating system currently running 10.4.8 when I plug camera in to final vut it not seeing the fire wire saying that iti is missing. Going to system profiler the computer can see the Sony Z1 but in final cut its not seeing it. Running final cut 5 with all the latest updates.
Cheers
Ross
Brad Bussé replied 19 years, 11 months ago 3 Members · 6 Replies -
Don Greening
October 9, 2006 at 6:12 pmross,
It might be a Quicktime thing. Try the fix at the link below:
https://docs.info.apple.com/article.html?artnum=301852
– Don
“Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
Brad Bussé
October 9, 2006 at 6:25 pmHmm, I’m having problems with FCP seeing my DV decks – I get audio but no video. I tried the Quicktime reinstall trick with no luck. I’ve now discovered that when I’m trying to log, I can see the video if I set the capture to DV PAL (even though the miniDV tapes I’m using were all recorded to DV NTSC). Anyone else experiencing this?
Don Greening
October 9, 2006 at 6:27 pmHave you tried trashing the FCP pref. files?
Don Greening
October 9, 2006 at 6:48 pmOkay. The next thing would be to make sure your DV decks haven’t been changed somehow so that they’re outputting in PAL instead of NTSC. Just a guess. This is uncharted territory for me, since I don’t use a DV deck, but just a FW camera. The fact that you’re at least getting the audio tells me that FCP and your decks are communicating (re: the QT fix above) but that they’re just not doing it properly. Sorry I can’t be of furthur help.
– Don
Brad Bussé
October 9, 2006 at 7:44 pmWell, I got it working. I switched out the firewire cable yet again, and this time plugged it into the port on the back of my G5 instead of the one on the front. Thanks all for your suggestions!
