Activity Forums Apple Final Cut Pro Legacy FCP not exporting 16:9
  • FCP not exporting 16:9
    Posted by Will Granzier on October 19, 2009 at 6:48 pm
    Pls someone help me here. Never had this issue before. I shot a project in 16:9 on a JVC 101. Edited in FCP 6 using DV 48 PAL Anamorphic, but the damm project wont export in Anamorphic !!!! It kepts pusing it in the 16:9 format but places my footage as a 4:3 dead centre . So it thinks its 16:9 – but the footage is 4:3 within a 16:9 frame ???? Frkkin Weird
    Am I missing something here
    Thnx
    Kevin Monahan replied 16 years, 11 months ago 3 Members · 4 Replies
  • Tom Wolsky
    October 19, 2009 at 7:27 pm
    All PAL is the same frame size, regardless of whether it’s anamorphic or not. I assume the media in the QT player is squeezed horizontally. If it’s being cut that’s a problem. If it’s squeezed it’s correct. It’s up to the playback application to interpret the material. You can do that in movie properties in the QT pro player.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Will Granzier
    October 19, 2009 at 7:44 pm
    Hey Tom
    Thnx for the response. See I want it letterboxed – not streched vertically.
  • Tom Wolsky
    October 19, 2009 at 7:53 pm
    If you want your 16:9 sequence letterboxed then you need to place your anamorphic sequence inside a 4:3 sequence and export that.
    All the best,
    Tom
  • Kevin Monahan
    October 19, 2009 at 8:20 pm
    In FCP 7, all anamorphic footage should export in the correct aspect ratio.
    Kevin Monahan
    60 Blu-ray Templates for Final Cut Studio 2009
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
