Activity Forums Apple Final Cut Pro Legacy FCP not capturing footage properly
  • FCP not capturing footage properly
    Posted by Nicholas Johnson on November 13, 2009 at 8:52 pm
    Running FCP 4.5 HD on a G5 Dual 1.8 ghz PowerPC
    Capturing to a WesternDigital “My Book” external HD
    Capturing off a Canon GL2 via firewire
    Only recently I’ve been having issues capturing footage – essentially playback on the camera and in the log and capture window is 100% fine but once I set FCP to batch capture the file come up problematic.
    The seem to lag on video – it will start fine but then the audio will continue but the picture will freeze. It will also jump footage and freeze frame again outside of the logged timecode even!
    I first though it was a GL2 problem, like the heads were dirty, but they’ve been cleaned.
    The other crazy thing is that iMovie has no issue capturing it!
    Tom Wolsky replied 16 years, 10 months ago 2 Members · 1 Reply
  • Tom Wolsky
    November 13, 2009 at 9:28 pm
    Canon cameras do not work well when there are other devices on the same bus. Either put the FW drive or the camera on a separate bus using a card or capture to the internal drive without the external attached and then move the media over.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
