Activity Forums Apple Final Cut Pro Legacy FCP No Longer Sends to Compressor?
  • FCP No Longer Sends to Compressor?
    Posted by John Jones on December 6, 2010 at 7:14 pm
    Hi, I am working in Final Cut Pro and I am trying to get some output using compressor. In the past I simply hit the menu item to send to Compressor, and compressor opens, the sequence shows up and you select the formats you want, it all worked very nice.
    Now I hit the menu item to send to compressor and compressor opens up but there is no window with my FCP sequence? I try the drop downs but cannot find the FCP sequence? Where did it go?
    I am able to “share” my sequence to encode to the standard DVD setting that were I guess used last time.
    As an aside, I am not able to use my droplets, they hang the system. They used to work fine.
    Help!
    John Jones replied 15 years, 8 months ago 2 Members · 2 Replies
  • Rafael Amador
    December 6, 2010 at 7:39 pm
    Hi John,
    Hake a Google search for a free application called “Compressor Repair”.
    Normally fix this kind of issues.
    rafael
    http://www.nagavideo.com
  • John Jones
    December 7, 2010 at 10:15 pm
    Thanks! Got it from download.com, now its working again.
