Activity › Forums › Blackmagic Design › FCP-Multibridge Extreme output
  • FCP-Multibridge Extreme output
    Posted by Miro Simeg on May 5, 2006 at 9:30 am
    I’m sorry for reposting but I can’t solve this.
    I work on Mac G5 Quad + FCP+Multibridge Extreme+Sony UVW-1800p.
    I had a problem with ref video which I solved with “Y looped trough ref in” trick. Do I still need blackburst generator? Soon I’ll get Digibeta deck, will I need it then?
    The other problem is that I can’t get video signal from FCP to Beta deck. I can’t find a problem… On a monitor (connected to Beta deck) I have a desktop background from computer, so I guess the video signal is OK, but I can’t get video or audio from FCP. And when I try to “Edit to tape” from FCP I get video out, but it looks like a “Purple haze” or rather “purple noise”. I’ve never seen anything like that.
    Any ideas? Anyone?
    One more question: what is NTSC/PAL REF IN on Multibridge for?
    tnx
    Miro
    Miro Simeg replied 20 years, 3 months ago 3 Members · 3 Replies
  • Chris Borjis
    May 9, 2006 at 5:39 pm
    If you’ll have digibeta you definitely want a blackburst generator.
    NTSC/PAL REF IN is where the black burst goes in.
    Also composite video goes in as well.
    I have my black burst normaled to the REF IN and when I used a cable
    on the patch bay from a composite deck it shuts off the black burst
    connection and puts the compoiste video in. works great.
    I’d email black magic support directly for your other problems.
  • Justin Tan
    May 15, 2006 at 3:11 am
    the purple haze you are getting could be due to having 444 out enabled in blackmagic preferences…
  • Miro Simeg
    June 5, 2006 at 8:33 am
    Unfortunately that’s not it. I’ve tried every setting available in blackmagic preferences but nothing helps. Someone told me that it could be that I have enabled component out instead of composite, but I don’t have that option in preferences. There’s only ‘All outputs active’.
