Activity Forums Apple Final Cut Pro Legacy FCP Multi-Clip Compressor Codec recommendation
  • FCP Multi-Clip Compressor Codec recommendation
    Posted by John Scott on April 13, 2011 at 9:57 pm
    Hello, I would like to know if there is a “recommended ProRes422LT settings” when wanting to
    use Compressor and limit the size of the output file and the time it take (2-6hours) for Compressor to change the codec.??. I have two formats that I want to make the same so I can use Multi-clip editing in FCP/.
    The first file is 1440×1080 29/97 HDV 1080i60. The Second file is a 1920×1080/29.97/Apple ProREs422 file. Now I know I want to down convert the ProRes file to the 1440×1080 format. Right?
    This is s for DVD release only.
    I have been experiementing with ths setup
    Description: Apple ProRes 422 with audio pass-through. Settings based off the source resolution and frame rate
    File Extension: mov
    Estimated size: 65.01 GB
    Audio: multi-track passthrough
    Video Encoder
    Format: QT
    Width: 1440
    Height: 1080
    Pixel aspect ratio: HD (1440×1080)
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Selected: 29.97
    Frame Controls On:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Fast (Line Averaging)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Same as Source
    Codec Type: Apple ProRes 422
    Multi-pass: Off, frame reorder: Off
    Automatic gamma correction
    Interlaced (top field first)
    Pixel depth: 24
    Spatial quality: 50
    Min. Spatial quality: 0
    Temporal quality: 0
    Min. temporal quality:
    Is there a way to do this diffently without making my file sizes so HUGE? 50gig or so…
    John
    John Scott replied 15 years, 4 months ago 1 Member · 1 Reply
  • John Scott
    April 13, 2011 at 10:03 pm
    One more question..
    I have more files to Log and TRansfer. Is there a way to Log and TRansfer my media files so that they will end up matching for multi Clip Editing in FC? Hence skipping the Logging and Transferring time then taking them to Compressor to make all in the same format?
    John
