Activity Forums Apple Final Cut Pro Legacy FCP & Mp4???
  • Posted by Colin Thrupp on February 28, 2010 at 1:10 pm
    hi guys,
    i have recently upgraded to FCP 7 and suddenly the clips i am trying to ingest via XDCam transfer (i run an ex1) are MP4 and won’t copy across… wtf?!?! it’s crazy because the week before i upgraded i ingested a project with absolutely no problems (the clips came in as MOV’s) but now when i tried to ingest the same clips, they’re MP4 and won’t go in? is there something i’m missing…???
    also, i have recently bought one of these GoPro Hero cams and a similar problem is present – they shoot in MP4 and FCP won’t let them in… even compressor won’t read them. is there a codec or some conversion software i need to get my hands on? and if so, where?
    cheers, col
    Brian Mccartney replied 16 years, 6 months ago 4 Members · 3 Replies
  • Ken Jones
    February 28, 2010 at 4:04 pm
    Are you simply “importing” or using “log and transfer”?
  • Zane Barker
    February 28, 2010 at 4:27 pm
    MP4 files are not edit frendly files you need to convert them to a proper editing format.
    Hindsight is always 1080p
  • Brian Mccartney
    February 28, 2010 at 6:53 pm
    I can’t speak to the MP4s from your EX-1 but I do know just a tiny bit about the GoPro. I just took some files from one of those a week ago and had no problem converting them to ProRes in Compressor. With a new install of FCP7 you should have everything you need. When you upgraded did you also re-install your OS?
