Activity Forums Apple Final Cut Pro Legacy FCP .MOV to FLV Conversion
  • FCP .MOV to FLV Conversion
    Posted by Tom Edwards on December 11, 2009 at 11:32 am
    Appreciate any help people can give me. I need to convert a FCP quicktime movie to Flash – professional standard – but am not sure which software to use. A friend suggested visual hub would have worked before it closed down. I’ve come across FilmRedux, which looks like the open source version of vis hub. Has anyone used this or can anyone recommend any other converters? (e.g iskysoft video converter for mac) – free if poss though. Never done this before so any tips welcome. Thanks.
    Tom Edwards replied 16 years, 9 months ago 2 Members · 3 Replies
  • Joel Peregrine
    December 11, 2009 at 3:14 pm
    Hi Tom,
    Its not necessary to convert quicktime to flv. Use QuickTime to encode with the H.264 codec, then delete the .mov extension and add .flv. Works perfectly and is an accepted standard.
  • Tom Edwards
    December 16, 2009 at 7:27 pm
    Thanks for the advice Joel. Exported from FCP using quicktime conversion with the following settings: H.264/Quality High: keyframe rate: 24 / encoding mode: multipass / dimensions: 640 x 360 Sound: Format: Integer/ sample rate: 48.000khz / sample size: 24-bit.
    Followed your advice, renaming the quicktime file extension as .flv – picture and audio fine on the mac but have had a call saying there is picture but no audio when playing through flash. Am I missing something out?
  • Tom Edwards
    December 17, 2009 at 9:11 am
    For example, would Zamzar work?
