Activity Forums Apple Final Cut Pro Legacy fcp motion problem on photoshop import
  • fcp motion problem on photoshop import
    Posted by Ian Futter on December 30, 2008 at 11:21 am
    After importing a photoshop multilayered file, i then added some simple scale and opacity motion to one layer in the nest and then put the photoshop nest on the main sequence timeline.
    I seem to get an interlace flicker when rendered, ive tried both lower and upper dominance, and none in the seq settings but no luck.
    Is this a known problem ?
    Ian
    Rafael Amador replied 17 years, 8 months ago 2 Members · 2 Replies
  • Ian Futter
    December 30, 2008 at 12:50 pm
    its ok ive solved it if anyone is interested, when a photoshop file, or graphics comp is added to fcp it puts a field ofset filter into the clip for no reason?
    i right clicked on the clip (so it doesnt auto open the gfx seq) and listed the filters and cut out the shift field filter then it works a treat.
  • Rafael Amador
    December 30, 2008 at 1:18 pm
    Hi Ian,
    What you should do is to check the .psd file as NONE in the FC Browser. You will avoid this kind of field-order problems. Stills shouldn’t have fields unless they cam from an interlaced Still Sequence.
    Cheers,
    Rafael
    http://www.nagavideo.com
